Old 09-13-2002, 07:37 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Definately get the blow proof bellhousing, also known as a scattersheild. Make sure you check runout on the scattershield as the instructions tell you to.
The SPF is setup for a hydraulic clutch. You can do it the easy way and just get a hydraulic throwout bearing, but I reccomend against that. Highly recommend a ford type TO bearing and fork, and an external hydraulic slave cylinder to move the fork. This setup costs less and is easier to repair.
