Old 09-13-2002, 06:05 PM
dgcomps dgcomps is offline
Thumbs up Alternator Brackets
After I signed off, I thought about two other catalogs that would be of great use. You should check the Summit and National Parts Depot catalogs. Contact NPD @ 1800-521-6104. They specialize in early Mustang components and have a great selection of parts. They are also very helpful. I found that repo 351 alternator brackets just don't work all that well. I have worked on 302 brackets and they work just fine. My alternator is located on the passenger side on top of the engine compartment.
The bracket setup I ordered from March did not fit and could only use the turnbuckle to tighten the belt. I am using a 40" serpintine belt and it works great!
I'll find the type of pulleys I used and write you back.
Dave
