Thread: Jag Suspension
Old 09-13-2002, 09:27 PM
I can shed a LITTLE bit of light on this. "Open" means for sure it is NOT a posi traction type unit. Open is often referred to as a "one legger", "a peg leg" etc., one tire spins not both.
I've had several XJS's (hey, I LIKE them). ALL the ones I had were "posi" units, maybe I got "lucky"? The XJS rear end is stronger than the XJ's had. But is probably not "lighter" over all. I was able to "break" the posi unit in several rear ends in the XJS, as I drove them HARD! I would be skeptical an XJ rear end could hold up to the high horse power normally found in a Cobra when used aggressively.
Then again, the XJS's were a HEAVY car. The cobra being lighter may well be fine with the standard XJ rear end. But NO WAY I would EVER use a "peg leg" in my car!
So why don't they recommend the XJS rear end as opposed to the XJ rear end? Price might be one reason! A lot of kit makers try to use examples of "donor" parts that are easy to get or are at a good price or have that sound of "good stuff" associated with it. That doesn't mean it's the "best way"!
Ernie
PS
Just broke the posi unit in my 9" Ford rear end too. I'm just HELL on wheels when it comes to breaking stuff, doesn't mean the Ford 9" is "weak", heck it's considered about as strong as they get!
