Old 09-14-2002, 01:37 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Also have TeamIII 17's on CR, MII front, late 8.8 w/disks rear.
Front backspacing on 17" x 8" was 4". Puts wheel centerline right on wheel mounting face. Tires are 235/45ZR17. 4" backspacing was also used on OEM CR Cragar 15" wheels.
Rear backspacing on 17" x 9 1/2" was 5". Puts wheel centerline slightly inside wheel mounting face. (4 3/4" backspacing would have worked also, but before having everything mounted up, thought was it would be easier to shim wheel out if additional clearance was necessary). Rear tires are 275/40ZR17. Everything fits, looks, and works great.
If using standard mid '80's 8.8 Mustang rear, this should work. Starting in '94 or '95, Mustangs with OEM rear disks (SN95) were wider, and this may affect your rear backspacing requirements. Check with Don Scott on exact measurements if this is the case.
