Old 09-17-2002, 07:06 PM
a427sc a427sc is offline
Scott, a little dumb math. Your old setup, 135/285=.47. New setup 180/335=.54. The ratio f/r old and new is pretty close, but you have stopped the roll over with higher rates, holding the front alignment, sounds good. My ERA is 189/282=.67, stiffer front, softer rear balance. The result of a large lump under the hood. Might still go a little stiffer in the rear if tweaking out the balance with the bars and shock valving doesn't get it. Now those FFR's, 240/285=.84! But it works for them, compensating for the spec suspension and shocks they have to run with no (?) bars. Quite the mystery, isn't it.
Don
