Old 09-20-2002, 12:36 PM
excelguru's Avatar
excelguru excelguru is offline
(An All-Around Nice Guy)
Cobra Make, Engine: Unique Motorcars (sold)
Question Various questions...
Here's what I'm reading... please let me know if some of these seem terribly wrong.
Oil Temp: 100 C (max when moving)
Oil Temp: 110-115 C (sitting in traffic)
Oil Press: 70-80 PSI (start-up)
Oil Press: 40 PSI (hot)
H2O Temp: 85 C (max when moving)
H2O Temp: 100-110++++ C (sitting in traffic)
(This engine does NOT like to sit still.)
Also, the shifter wants to "pop out" of 2nd and 4th gears. Is this a linkage adjustment problem?
Which way do I turn the brake-bias adjusting rod (at the pedal) to move the bias towards the front brakes and off the rear? When viewing the brake pedal from the driver's seat, the front brake cylinder is on the left and the rear is on the right. And there's a pivoting rod between the two that passes through the brake pedal (standard Wilwood unit).
Thanks as usual! Gotta go!
Keith
Keith
Former Unique owner.
