Old 09-25-2002, 11:08 PM
Monster's Avatar
Monster Monster is offline
Cobra Make, Engine: Arntz/Bennett, FE with lots of shinny parts that make it go fast
I've actually decided to start very basic, I've picked up another bottle of WW and I'm going to try that first. The range of coverage for a bottle of WW is "1 bottle per12 to 20 quart system", I'm actually closer to 6 gal. or 24 qts. so I figure that being close to the limit of coverage, I may not be getting the full benefit of the product. @ $4.99 a bottle its jsut as cheap as a thermostat and easier to install. Anyway my approach to diagnostics is to first check all settings and make sure everything is within spec. So, we'll see if I need to spend another $4.99 on a thermostat after I test the car tomorrow.
Also on the subject of 160 vs. 180 thermostat I'm not sure I follow the logic. A 160 will open sooner however, the engine does not continue to run at 160. Most will continue to increase in temp to around 180-185 I would guess. A 180 will not open full until 180 however, both the 160 and the 180 are open full once the engine is at operating temp which as I said I believe is normally 180-185. Plus, most electric fan thermo switches turn the fans on at 195+ so the engines would seem to always exceed the 180 mark and the thermostat should always be open full. So,What is the benefit of running a cooler thermostat?
Thanks,
Mike 'monster'
