Old 09-27-2002, 09:55 AM
Pete C's Avatar
Pete C Pete C is offline
Cobra Make, Engine: ERA 427 SC #004 (Original ERA?)
Default excelguru
Fix It is dead on right. The problem is with stud to hub alignment. The wheels are correct it is the mount point that is sometimes the problem. Dont grind just straighten. If you grind and then by driving the studs straighten you will have a whole new set of problems due to play. If you modified any of the trigo pins have him send you new ones.
Cheers, Pete
Drive it like you stole it!
