Old 09-30-2002, 03:29 PM
A Snake A Snake is offline
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
Right on Mr.Fixit. My dial indicator has a large magnetic base and the dial itself has 1 1/2" of stroke, so using the crank alone worked fine for me, but I must admit the flywheel is more forgiving and takes less screwing around.
I think we should add a note here: Check ALL aftermarket bellhousings for concentricity and square (parallel surfaces on flange to block face and trans face) before using them. Don't just assume because they're new they must be right. Most of them are not.
BTW I love those offset dowel pins! What a breeze to use!
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
