Old 10-03-2002, 09:23 AM
mikiec's Avatar
mikiec mikiec is offline
When you take the wheel off to check....over inflate the tire. Get a soapy water mixture and pour it slowly over the tire. Rotate the tire and check for air bubles. Do the same for the bead on the rim and valve. If the valve is leaking either tighten or replace it. If there is a slow leak in the tire have it patched.
Mike
