Old 10-04-2002, 09:00 AM
Ron61's Avatar
Ron61 Ron61 is offline
Ernie,
We have had five cars go through up here on SB-100 and all went right through without any problem. They did have to have a sniffer test but were registered by the body style which is the owners perogative. They do a sniffer test and none of them would have come close to passing but that must be for paper work as after that was done the referee put the sticker on that it weas a special construction vehicle and exempt from smog. One guy has a 504 with two fours and it would be a gross polluter by todays standards. As for out of state cars that have titlels in other states I think SB 1578 addresses that issue. I have a copy of it and the only thing I see that may hang anyone up is that those cars also count against the 500 per year allowed under SB 100. However SB 1578 also has some requirements that if you try to register after the intial 500 are used, then things could get a little hairy from the way I read it. Jamo or Bonyhadi should be able to explain this much better than I.
Ron61
Ron Widener
