Old 10-04-2002, 05:17 PM
Hi chaplin You are buying one of the best cobras built today, why would you want on put lug nut lugs wheels on your car??? When properly installed and safty wired, you have no problems to worry about, except a flat tire. Any good tire place can fix it with no problem. You can get a safety clip for each wheel through ERA. Talk to Peter P or Bob P. about your worrys. I have 15" and 17" wheels and tires and both look great on the car. The 15" are for street and the 17" are for roadracing and autocross. Get a 4lbs. brass or deadblow hammer to knock the spinners on and off the spindels. I think you will be very happy with the latter choise. Good luck with your car. Rick Lake ps Mike get the car together and ask pete if he has a set you can put on your car, you will like the look. People at Run&Gun use knock off, I have not seen a wheel come off yet. Some of these cars are racing in the 150 mph speeds with no vibration or loose problems happening.
