Old 10-05-2002, 02:36 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Bob-
Apparently the minimum back space Phil can do on the bolt-on wheels is a 4" back space- I think you recommend 3 5/16". Also, the PSE bolt-ons have the following dimensions: front rim 15 x 7.5; back rim 15 x 9.5. I think you recommend 7" wide in the front and 10" in the rear. I suppose they are close enough that they would work, but would it "look right"? After all, the look of the rear fenders/tires is what made me decide to buy an ERA in the first place. I don't want to wreck it by putting on wheels which throw off "the look". If I get pin-drive, Phil can make them to the required back space.
Do you know if Team III makes a GT-40 style wheel?
Rick-
Maybe you're right, maybe I should go with knock-offs, buy a BFLH (Big F***in' Lead Hammer) and stop worrying about it.
Replica is not a dirty word.
