Old 10-07-2002, 09:31 AM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
Roscoe
First off, I'm glad to hear that you finally found the source of your heating problem.
I was wondering if the problem with the old pump could be the impellor slipping on the shaft, this would probably only occur at higher than idle revs. Why don't you put the pump in the vice and see if you can force the impellor to turn on the shaft, just out of curiosity. It would be interesting to see if this was the real problem.
Wayne
Don't get caught dead, sitting on your seat belt.
