Old 10-11-2002, 02:56 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
There is some normal heat expansion of the coolant. If you keep topping the system off while cold, it will keep blowing out that pint of coolant everytime it heats up to operating temps. Is the overflow tube on the expansion tank after the cap, requiring more than 16 psi to get coolant into the catch can. Or is it part of the pressurized system, making it a (non-pressurized) system with tiny hole way up high that some coolant can get out of.
