Old 10-15-2002, 08:53 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Two things can cause your problem. A) the main idle / throttle screw could be hanging up on the lever / carb base plate causing it to not fall closed all the way after the heated body / baseplate has warmed up (warmth=expansion) Or B) you have the idle circut improperly adjusted.. The screws are located on either side of the carb body, with a vacuum gauge close one, then the other adjusting for optimum idle / vacuum..
Regards,
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
