Thread: Cylinder Heads?
Old 10-18-2002, 09:35 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
The two advantages that have made me decide to go with aluminum are weight savings and better heat dissipation which means that you can effectively run a slightly higher compression ratio than you could with cast iron head without the risk of detonation. Not to mention that you average modern aluminum cylinder head will have a better design and flow much better than a factory cast iron head.
Anyone else?
Replica is not a dirty word.
