Old 10-20-2002, 08:04 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Jack,
When you get around to pulling the sending unit from the tank..give me a couple days notice, OK?
I don't think I want to be here when you find the problem. It's not hard to adapt a new sending unit, but it is a pain in the arse!
OK, here tis, chances are you will find the sending unit, along with the pick-up tube covered in rust. Seems a lot of "Tanks" came in to Roadsters without enough "presevative" to keep the tanks clean and rust free before they actually got used.
I haven't seen this problem for more than two years. Maybe you got one of the old ones.
DV...if this is the case, their is a slight chance a simple and thorough cleaning will fix the problem.
