Old 10-21-2002, 12:47 PM
chopper's Avatar
chopper chopper is offline
Cobra Make, Engine: Previous ERA owner on break
Default Regulators
SSSnake:
Just a random thought here. You didn't say what fuel metering system you plan to use when you get the engine installed (carb or EFI). I can't tell from your photo, but it doesn't look like you have a pressure regulator hooked up to this system (unless, of course, you are planning to add that up front). However, the Holley BLUE pump (according to their website):
http://www.holley.com/HiOctn/ProdLin.../12-802-1.html
is factory set to 14 psi output. Their graph shows relatively stable pressure output of 12 - 14 psi up to 80 gph. This pressure is more than the needle valves in most carbs can handle, so a pressure regulator is usually required for carbed engines when running the BLUE pump. Their RED pump (the one I use) is set up to about 7 psi; I've measured mine at about 6 psi at idle and decreases to about 4.5 at cruise. It's my understanding that if you run much more than about six psi, you can overpower the needle valves and flood the carbs. Just something to consider. If I missed the regulator installation in your photo, kidly disregard all after "Hello" and I'll fade quietly.
Some folks drink from the fountain of knowledge; others just gargle.
Yesterday's flower children are today's blooming idiots.
