Old 10-21-2002, 02:31 PM
flipper35's Avatar
flipper35 flipper35 is offline
Cobra Make, Engine: Shell Valley, Mopar thingy (small block of course)
You may try Keisler (sp?) Engineering for a bellhousing to fit. Hays may also have a non-SFI approved bellhousing for you. Clutch set-up should be easy. Matching the input shaft to crankshaft bushing/bearing may be. I am sure a performance machine shop could drill and machine the proper bolt pattern for you also.
Brent Dolphin
