Old 10-23-2002, 02:50 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
I plan to go a bit further...maybe 2,500 to 3,000 miles on 20/50 Castrol or similar.
Some in the know like to test for compression...when it tops off and no longer increases...then the rings are set and you can switch to synthetic...Mobil 1 is a good readily available synthetic of very high quality. I plan to use a custom blend of different weight Royal Purple synthetic..since they don't make a multi-vis with the heavier weights I want. (about 5/20/40/50)
Maybe more important is the oil FILTER...never use a Fram...they are very restrictive, especially at start-up.... Mobil 1, or K & N would be my top choices in a filter...but there are others also..there is a very good thread on this (oil and filters) in the archives.
I went with K & N because it was good, and the black matches my SVO 514 block
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
