Old 10-27-2002, 03:12 PM
Hi Chuck I have studs on my Shelby motor. I can get the heads off BUT you have to twist the motor to clear the body. Snap-On sells a stud remover for 7/16, 1/2, and 9/16 studs that you can use to remove the studs. Don't use VISEGRIPS. If worst case comes, put two nuts on the studs, tighen and remove that way. Studs are better that bolts are either Alumium or Iron heads. ARP is the way to go. Don't forget the harden flat washers. Rick Lake
