Old 10-28-2002, 06:27 AM
To Bob P Thanks Bob, I learned from the master. Hows the roll bar coming? Chuck it is a bear to get whose heads off in the car. You can pull the motor in and hour, as to not scratch our car. Just a thought. Chuck you didn't say which heads you where using ? Bolts will work just fine if you are not building a 11.0-1 compression motor and not turning 7000 rpm. You have to use studs in a Shelby motor because the stress on the heads is being held from the bottom of the block. This block will take 2,000 hp and live. I am overkill for my car. Good Luck Rick Lake
