Thread: Cam question
Old 10-29-2002, 05:16 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
I'm not an FE guru, and it depends on more parameters than just the cam, (heads, intake, carb) but neither cam is going to give you what you want.
Go with a flat tappet hydraulic, or retrofit hydraulic roller. Intake duration should be in the 222 - 224 (@.050) range, and exhaust up to 232 - 234 range if you use a dual pattern cam. This should put your torque peak at 3500 - 3800 RPM, and HP peak at 5500 - 5800 RPM. Motor should idle at 750 - 850 RPM with a nice rumpeta-rumpeta lope, and pull like a diesel from off-idle - up.
