Old 10-30-2002, 10:43 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Why would you want to thermal insulate all your engine (or brake) components? You need you engine parts to be able to rid themselves of heat by transferring it to the oil. The coatings that they put on piston tops and combustion chambers are different that those on the exhaust. Ceramic exhaust coating can and does chip off too.
