Thread: Cam question
Old 10-30-2002, 12:19 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Mr Mike,
That is a good street cam that will make power down low in the rpm's. What are your gears and compression? You'll need good amounts of both to make a big duration cam work. I would go for a few more degrees on the intake side, and 10 more than the intake on the exhaust side. Dual pattern cams are great.
