Thread: Cam question
Old 10-30-2002, 07:14 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Mike:
I'm guessing you are using hydraulic lifters. I now understand why you chose the cam you did from Ultradyne. I went to their web site tonight, their reccomendations seam very conservative. I would reccomend Crane grind number H-296-2. It is number 6 on the link below. It has a 112 degree lobe seperation, which will give you a nice idle, 234 / 238 duration @ .050 and .554 / .563 lift.
Crane Cams
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
