Old 11-01-2002, 10:42 AM
FE Specialties FE Specialties is offline
Hi Paul,
Valve rotators are for high mileage type engines, non-performance. These add a whole bunch of weight to the valvetrain, so this is diffenetly out in a performance application. If the rocker is not centered on the valve tip, then you start side loading the guide and it wears out quite quickly.Your centering is exactly what you want on your motor.
The wear can come from, now get this, either not enough, or too much valve spring pressure! If you have a fairly big cam, and are reving it high, if you dont have enough pressure, your valve will bouce on the seat, there by hammering the valve tip against the rocker. Similarly, if you have too much pressure, especially open pressure, it can cause scrubing on the valve tip if there's not enough oil getting to the valve train at high RPMS.
Hope this helps!!
Tom, FE Specialties.
Tom Lucas, FE Specialties Sacramento, Calif. 916-339-0427. Our Engines are designed and engineered, not just thrown together. I design engines for every application. From mild street engines for torque to mid type performance engines for Cobras and Mustangs too fullout Race engines for Nascar and NHRA.
