Old 11-01-2002, 10:25 PM
Steve Dickey Steve Dickey is offline
Michael
You can buy a heavy duty spring for the pressure relief valve and forget the shimming. Call George at Gessford. Make sure you install it correctly, spring first, then the piston with the skinny pointy end facing out.
Also, don't forget the plug in the top oil gallery that exits behind your cam gear. A screw up I've just recovered from and I'd hate to see anybody else make.
Good luck, Steve
