Old 11-03-2002, 02:57 PM
427 S/O's Avatar
427 S/O 427 S/O is offline
For you guys with pinion seal leakage on your Jag rears, I found (with help) a little trick that might help....
Mark the end of the pinion shaft and nut with a sharp chisle, in-line with each other. When replacing you have the correct mark so not to under/over
tighten the crush washer/shim.
Worked for me, after 700mi, no noise/leaks.
Perry
