Old 11-04-2002, 05:37 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
OK Racing,
Be very sure you have your lines correctly installed. Before you fire your engine pull your distributor and use a 1/4" extension with either a 5/16" or 1/4" socket to manually turn your oil pump counter clockwise. You should be able to see significant oil at your rocker arm stands. I am speeking from experience I burned all my bearngs and three pistons in less than 15 minutes. VERY EXPENSIVE mistake.
Hopefully, you are not running stock rocker arms because if you intend to do any racing they will not hold up very long. Also, speaking from experience on this too. I have had one heck of a learning curve this year.
Bob Putnam will show you the correct way but still check everything before you fire.
Clois
"Let's roll"
"Be part of Something Good
