  #38 (permalink)
Old 11-06-2002, 05:26 PM
Cobranut Cobranut is offline
Cobra Make, Engine: Genuine original Unique MotorCars 427 S/C, with a Genuine original Ford 427 Side-oiler.
Send a message via Yahoo to Cobranut
Jerry,
Thanks for the info. You may be correct about the phos limit applying only to the lighter weight oils.
I went to Mobil's website and they make a definate distinction for the 15w50 weight. They refer to it as their "Performance Driving Formula" and state that it "Contains additional wear protection required for racing type engines."
I suspect (and hope) that this may be the higher phos. content.
Steve,
Actually, the PSD holds 15 quarts, and usually needs 1 quart added at about 3-4K miles when used for heavy towing. (Which is what we bought it for anyway). Plus, the filter is about $9.00.
So an oil change with Delvac-1 would be over $90.00, versus $33.00 using Rotella.
Later,
David
