This is what I did on a set of pipes....drilled 2 small holes, about a foot apart on the bottom of the pipe. Then tacked the baffle to the pipe, and filled the holes. Used a grinder to take care of extra fill. Put pipes back on car and you'll never see. You need to tack both ends of the baffle. Only tacked one end first, and other end still made noise....
Jack
XSSIVE .....
