Thread: Cam Shaft Help!
Old 11-10-2002, 09:39 AM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
What makes an FE so different that you need to only run the outer spring on break-in? Pressure is pressure. I don't believe it unless somebody can explain.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
