Old 11-10-2002, 07:19 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
4V Highrise will not fit in a Cobra without a tall hood scoop. Also would need heads to go with it. You would also need special custom made headers.
The cam you speak of is total duration (306 degrees), not at .050.
I will try to run the numbers the best I can. If you give me the exact cam, we can get closer. Have the heads been ported at all?
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
