Old 11-12-2002, 10:35 AM
agro1 agro1 is offline
Cobra Make, Engine: SPF - 427 Stroker
Default Strange Coolant Leak
Went for an hour long drive last night. No thrashing, just mellow cruising. Backed the car into the driveway and shut 'er off. Noticed a small amount of coolant under the car after I started it back up and went to move it into the garage - Water temp started to climb a bit and then leveled off at normal temp...There was a bit of coolant around the motor over by the water pump but I could not see any leaks or where it could have come from... I let it cool down then started it back up and let it idle for a bit - Water temp fine...Any ideas ?
NEVER LIFT
