Old 11-13-2002, 07:54 AM
agro1 agro1 is offline
Cobra Make, Engine: SPF - 427 Stroker
...Turns out is was coming from one of the water inlets on the water pump. The brass hose fitting was loose in the pump (??????) but the hose clamp was nice and tight. So I just removed the hose and fitting, cleaned'em off, used some new teflon tape and tightened that sucker back down...Seems to have done the trick. Thanks for the suggestions.
NEVER LIFT
