Old 11-13-2002, 02:55 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Sparkplug style distributor lugs.
Is it merely the ford "big cap" ? If the ignition coil is in the cap itself, it is HEI type, if it is merely a big honkin cap with sparkplug type terminals, you will have no problems. What kind of adapter is on the distributor housing that allows the HEI type cap to fit? I hope that can be changed otherwise you will have a hard time getting a small cap to fit correctly on your housing.
