Old 11-14-2002, 02:41 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Exclamation One point...?
I would not use WD-40 ! It is HYDROSCOPIC...meaning it actually attracts moisture.... ! My recommendation would be for a pump spray of 5 or 10 weight synthetic oil...or maybe some sort of tool preservative spray oil...
Don't forget that you can place a dessicant pak in your air filter housing to help out in this regard...but use a written checklist for re-activating "her" , so you don't forget it!
Something else that helps are "Golden rods" they are the type of electric heater rods used in display cases and safes...( www.griotsgarage.com ) properly placed they can keep your trunk/cockpit dry and freeze-free all winter...as long as it's in covered/garage storage
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
