Old 11-16-2002, 09:09 PM
ls1ac's Avatar
ls1ac ls1ac is offline
Most systems with a bypass use a three way valve. This stops the flow from going through the cooler, but the return pipe is still connected to the system. This means that when the system is under pressure after startup the oil will be returned to the accusump by way of the retun line. It will not stay in the crank case.
HAVING TOO MUCH FUN
Scott
