Old 11-18-2002, 05:25 PM
TFIVEUK TFIVEUK is offline
The fuel bowls on the Edlebrock are on each side; the problem is quite specific and infact its not a problem at all; the fix is listed in the Carbs userguide and takes about 10 mins to do and a whole lot cheaper than ruining a perfectly good intake manifold by milling it which will cause cylinder distrubution problems.
Edlebrock are exceptionally good carbs; made by weber, they are just different to Holley's and therefore people don't understand them and think they are crap. The Edlebrock is quicker to callibrate than the Holley and probably better designed but If people can't be bothered to read the instructions then I guess there is no hope!
P.S. I run a Holley for authenticity but think an Edlebrock is better.
Fraser White
www.T5UK.com
