Old 11-20-2002, 09:20 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Ditto to Black in Black
I've seen too many threads stripped and bolts broken just because someone had to turn a bolt or nut to make sure it's tight. If a fastener doesn't turn when the specified torque is reached, for heaven's sake don't turn it at all. Then you won't make the mistake again.
Good luck on the fix, HeliCoil, that is.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
