Old 11-20-2002, 03:06 PM
Tom Decker Hi Tom, You should check with who ever you are going to use for your FI. FAST is the only true Sequential brain on the market that goes to 10,000rpm. Most ECM's go to batch fire at a certain rpm, I think it's 3000 rpm. My speed-pro was 3,000$ 3 years ago. The full sequential box was 5,200$. You do not need wideband unless you are running NOS or supercharging. Check around befor you buy something you don't need. I have both a cranktrigger and distributor signal for my system. I like the fuel and timing control of each cylinder. MSD will make a dual pickup distributor if you talk to one of the techs. It seems that the top housings are the same between single and double pickup's. Good luck Rick Lake
