Old 11-21-2002, 07:12 AM
Blake Olson's Avatar
Blake Olson Blake Olson is offline
Location: Right in the middle of the beautiful Texas Hill Country - Boerne, Texas,
Send a message via Yahoo to Blake Olson
Default B&B 5 Point Harness Install
Ok,
I finally got the 5 point harness installed in the B&B. The carpet that B&B uses "runs" easily, so be careful when cutting the holes behind the seat.
Here's some photos of the rear install. There is a piece of 2" square tubing tha the roll bar is installed on, drill holes(one of each side) through that....grade 8 bolt/washer/lockwasher/nut..and you're done.
I had a custom made bracket for the anti-submarine belt made..I forgot to take photos before I put the seats in. I will do it tonight and post photos. It's really trick.
This will get you started...more to follow tommorrow.
"They're lining up on both sides of the ocean..
and nobody's willing to compromise
in the search for the smoking gun..."
"Charlie Don't Surf!"
