275/50 work good. i you go with the wider tire make sure you have more room in and on the outside of the wheel well. some cars the inner body and frame are close and i may rub. the best thing is to take it in and have them mount one and visual check on the ground . good luck. i will try and use up my 275/60 then drop t the 50 series in the rear.
Well officer.. It was like this.
