Old 12-02-2002, 09:51 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Question Autometer makes small, discrete "warning lights"...
I wonder if I could just hook them up to the sender units for oil pressure/voltage/and oil temperature...and mount the (really small..looks like a tiny shift light{s} ) on my column or in some other out-of-the-way spot?
The voltage level GUAGE I have should also show a drop if there is a charging or ground/connection problem.
This way if the light comes on, you can stop and look at your voltage guage to see if it has dropped...and look at your electric oil pressure/temperature guages also? ...And maybe stop at a nearby shop and have them check oil pressure..etc?
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
