Old 12-02-2002, 04:14 PM
Steve Elias Steve Elias is offline
Thanks for the advice MR.Fixit. I did drain the red line out and will save it. lots of break in lube on the gear. I set the dist up with the blue stop bushing "21 degree" with 11 initial all in by 2500 for total of 32. no vacuum advance. I will go real easy for a few hundred miles and check the gear often, and let you know. Thanks.
