Old 12-03-2002, 02:36 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Junket, I'm assuming this is the Lucas motor. With the 5 lug switch facing you, you will have 2 lugs top, 2 lugs bottom, 1 lug left. This is how I wire the motors.
Top and bottom right lugs tied together and running to low speed on switch. Bottom left lug to high speed on switch, top left lug to power, Left vertical lug, remove blue wire from back of wiper switch and run the blue wire to ground.
I then use a 3 position switch with power in, high and low speed from motor to 3 position switch. You should have high and low speed and park. I hope this makes sense!
Don
