Old 12-06-2002, 11:43 PM
Bill E's Avatar
Bill E Bill E is offline
JLW DV,s method will work. The idea is to shock the joint and bounce the pin out. remove the caliper and roater so you can get a good swing If that doesn't not work use a sledgehammer as a block on the other side then hit it, should do the trick. let us know how it go, s
Bill Emerson
