Old 12-07-2002, 02:44 PM
GREENSNAKE's Avatar
GREENSNAKE GREENSNAKE is offline
Default Tig Welder
Hey I run a Syncrowave 250 & 185 Best Welder for the Buck Also if your running your welder with Max amps you might want to go with 100 Amp breaker or you Will be popping the Breaker a lot thats if you have the Heavy duty Electrical Wire in your Shop If not you might melt your Electrical Wire. Later Lonny
